Warning! MK808B copy.
Postby deadhp1 » Wed Jan 02, 2013 2:04 pm
This is a warning that there is an MK808B copy floating around on the internet.
It uses the Mediatek wifi/bluetooth chipset instead of the RK902 used in the official MK808B.
It is also limited to a maximum speed of 1.2GHz.
If you use the MK808B firmware you will lose wifi and bluetooth.
So for now I am stating that the firmwares supplied in here should ONLY be used for the MK808B purchased through geekbuying.
So far the MX1 firmware is the closest, but will not work properly due the "copied" MK808B not having the same power controller.
There is no source code available for the Mediatek wifi/bluetooth, so I cannot make a custom kernel for it.
The only thing that can be done is to hound the seller you purchased the copy from for an official firmware.
If you open your MK808B and it looks like the below picture then you have the official MK808B:
If your MK808B looks like the below picture then you have a copy:
Yakuzza
Re: Warning! MK808B copy.
Postby Yakuzza » Wed Jan 02, 2013 3:05 pm
thx very much for the info!
btw. what´s the copy and what´s the original in the case of these sticks i wonder, who was the first who designed the ug802/mk808/mk808b ?
i know there are retailers to brand their sticks but what´s the original ?
And where are the kernelsources :) ? *just kidding on that*
eyesoft
Postby eyesoft » Wed Jan 02, 2013 3:38 pm
ok , i have a mk808B with mediatek chipset , but my maxium speed is 1608 Mhz, bluetooth work without problems
my wifi it's connected at 130 mbps ... and really i don't have any problem with this dongle ... i've managed to get root.
here you can see other factory who sell MK808B ... really now which one is a copy :D
http://www.alibaba.com/countrysearch/CN/mk808b.html
thnx
eyesoft
Postby eyesoft » Wed Jan 02, 2013 3:48 pm
deadhp1 can you tell me how to save current firmware or how to extract kernel or drivers from firmware to help others who bought MK808B with mediatek chipset ?
eyesoft
Postby eyesoft » Wed Jan 02, 2013 4:11 pm
uname -a
Linux localhost 3.0.8+ #89 SMP PREEMPT Mon Nov 26 18:00:11 CST 2012 armv7l GNU/Linux
dmesg
<4>[ 24.435090] =======================================================
<4>[ 24.441394] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 24.447811] =======================================================
<4>[ 24.454265] MT5931 SDIO WiFi driver (Powered by Rockchip,Ver 1.08) init.
<4>[ 24.461241] ## Calling platform_driver_register
<4>[ 24.465865] ## wifi_probe
<4>[ 24.470117] wifi_set_power = 0
<6>[ 24.473180] rk29sdk_wifi_power: 0
<6>[ 24.708242] wifi shut off power
<4>[ 24.722147] wifi_set_power = 1
<6>[ 24.725201] rk29sdk_wifi_power: 1
<6>[ 24.846805] wifi turn on power
<4>[ 24.849892] wifi_set_carddetect = 1
<6>[ 24.853389] rk29sdk_wifi_set_carddetect:1
<6>[ 24.857401] mmc1: slot status change detected(0-1)
<6>[ 24.862299] rk29_sdmmc_change_clk_div..1921.. newDiv=42, newCLK=294Khz [sdio]
<4>[ 24.871386] wl_android_wifictrl_func_add success.
<6>[ 25.069615]
<6>[ 25.069627] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc1]
<6>[28700.708545] [BT-PLAT] mt_bt_power_on ++
<6>[28702.139558] [BT-PLAT] request_irq IRQ282 success
<6>[28702.144174] [BT-PLAT] mt_bt_power_on --
<6>[28702.660592] rk_serial rk_serial.0: serial_rk_init_dma_rx sucess
lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 002 Device 002: ID 1a40:0101
Bus 002 Device 003: ID 0951:1607
lsmod
wlan 224032 0 - Live 0x00000000
vpu_service 11655 0 - Live 0x00000000
rk29_ipp 9541 0 - Live 0x00000000 (C)
mali 101298 16 - Live 0x00000000
ump 26148 21 mali, Live 0x00000000
rk30xxnand_ko 907691 0 - Live 0x00000000
/proc/cpuinfo
Processor : ARMv7 Processor rev 0 (v7l)
processor : 0
BogoMIPS : 2015.34
processor : 1
BogoMIPS : 2015.34
Features : swp half thumb fastmult vfp edsp neon vfpv3
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
Hardware : RK30board
Revision : 0000
Serial : 0000000000000000
Soul
Postby Soul » Wed Jan 02, 2013 8:17 pm
eyesoft, you would be a hero if you could extract the firmware! Then i could get my damn fake stick going again! :)
Im hoping someone can help you.
Postby deadhp1 » Thu Jan 03, 2013 2:35 am
eyesoft wrote:uname -a
dmesg
<6>[ 25.069615]
lsusb
lsmod
/proc/cpuinfo
processor : 0
BogoMIPS : 2015.34
processor : 1
BogoMIPS : 2015.34
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
Revision : 0000
Since it looks like you still have your original firmware I can help you rip the kernel out of it!
First off you need to be rooted for this to work.
Using terminal emulator enter the following commands:
su
cat /proc/mtd
This will give a list of where things are stored.
For example my kernel is stored on mtd1, my system.img is actually known as backup and stored on mtd4.
Sometimes backup is filled with garbage, sometimes it actually has the system.img. It really depends on how they built the firmware.
So now we'll use simple commands to rip these files to the internal sd card partition.
cat /dev/mtd/mtd1 > /sdcard/kernel.img
cat /dev/mtd/mtd4 > /sdcard/backup.img
Hope that helps!
eyesoft
Postby eyesoft » Thu Jan 03, 2013 2:55 am
i use ssh since i'm not home
cat /proc/mtd
dev: size erasesize name
mtd0: 00400000 00004000 "misc"
mtd1: 00800000 00004000 "kernel"
mtd2: 01000000 00004000 "boot"
mtd3: 01000000 00004000 "recovery"
mtd4: 18000000 00004000 "backup"
mtd5: 08000000 00004000 "cache"
mtd6: 40000000 00004000 "userdata"
mtd7: 00400000 00004000 "kpanic"
mtd8: 20000000 00004000 "system"
mtd9: 154400000 00004000 "user"
cat /dev/mtd/mtd1 > /mnt/sdcard/kernel.img
cat /dev/mtd/mtd4 > /mnt/sdcard/backup.img
-rwxrwxr-x system sdcard_rw 402653184 2013-01-03 06:47 backup.img
-rwxrwxr-x system sdcard_rw 8388608 2013-01-03 06:45 kernel.img
i've attached kernel.img , i download now backup.img (384 MB) from dongle ... i don't know if i can upload this here .
eyesoft
Postby eyesoft » Thu Jan 03, 2013 2:58 am
sorry but : The extension img is not allowed.
i will try to uploded else where.
eyesoft
Postby eyesoft » Thu Jan 03, 2013 3:02 am
https://www.dropbox.com/sh/4n2z4dadi30obrf/VVm76P9Idy
i put here kernel.img , after i download remote backup.img i also put it here.
eyesoft
Postby eyesoft » Thu Jan 03, 2013 3:08 am
for some reason , i can't download backup.img ... i can put it on my dropbox only when i get home ... now i'm at work.
Postby deadhp1 » Thu Jan 03, 2013 3:11 am
backup might not be what you need.
I've been testing out the commands on my MK808B with rk903.
after mounting the backup.img it didn't contain anything that I could use.
system contained all the system files from system.img
eyesoft
Postby eyesoft » Thu Jan 03, 2013 3:25 am
can you use only kernel.img ... and the original firmware for MK808 ?
Postby deadhp1 » Thu Jan 03, 2013 3:53 am
you won't have working wifi like that.
You need to have the kernel modules and bluetooth setup stuff that's in the system you have.
You might be able to use the imito system, but who know's if it will work.
I wish I could test this for you guys, but I don't have the same mk808b :o(
eyesoft
Postby eyesoft » Thu Jan 03, 2013 4:13 am
if you upload a rom with this kernel , i think someone can test it ... anyway people who already burn the rom for MK808 on MK808B with mediatek chipset ... have nothing to loose because the wifi and bluetooth don't work, only solution for them now is to use a usb-lan.
thnx
rbkcollc
Postby rbkcollc » Thu Jan 03, 2013 4:16 am
I have face the problem with MK808b with mediatek wifi. I flashed it with firmware available but now my wifi & bluetooth is not working...
rbkcollc
Postby rbkcollc » Thu Jan 03, 2013 4:39 am
Yes, this is the same what i got from YIYATE store.
eyesoft
Postby eyesoft » Thu Jan 03, 2013 4:56 am
one funny thing, they have no clue what are selling :
i bought my MK808B from mixeshop ... and i wrote them to send me from where i can download stock firmware , here is the answer :
hi friend
you can download here http://blog.geekbuying.com/index.php/20 ... e-release/
tina
If there is any question , pls reply me email.
Mixeshop
best wishes
YaoXin Electronics (hongkong)limited
http://www.mixeshop.com
http://www.yaoxincn.com
Tel: +86 -755-61892626
Contact Person: Tina Mobile:+86-13590115146
MSN:tina00_star@hotmail.com
Email:tina-yaoxin@foxmail.com
yahoo: yaoxincn01@yahoo.com
skype:shelayao
germanoob
Postby germanoob » Sat Jan 12, 2013 11:30 am
I've bought a MK808B from geekbuying, but it seems to be "the original" or "the official". So nobody seems to know, what he will get.
So I will try the firmware from XDA. later.
djeaton
Postby djeaton » Sat Jan 12, 2013 1:18 pm
Is there any way to tell you have a fake without breaking this thing open? For example, is there a difference in what it says in the About Screen in settings? If I *have* to break it open, just how do I do that?
