!NEW! MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
mumin0
Re: !NEW! MK808 Hybryd FW V2.0.0 !NEW!
Postby mumin0 » Sat Jan 05, 2013 10:57 am
Try this, I compiled the driver you requested using the kernel source code posted here
now small update of my problem
i downloaded Your file and tryied to insmod it. and :lol: :lol: :lol: it said it is already there.
now funny part when i lsmod it is not there :shock: :shock: :shock:
i tried to remove it with rmmod but i get (errno 2)
I checked dmesg and i see that when connected it is loading ok, system start it ok and i see right mac address and that interface is named eth0.
after command "ip addr" i see all interfaces and also my new eth0 with right mac address
Now my problem is that if i make dhcpcd -d eth0 i get ip like 162.186.102.201 so it gets none :cry:
i can set stable ip with ifconfig but even then i cant ping any of devices
and when i connect and disconect cable i get on dmesg "link down" and "link up, 100Mbs, full duplex, lpa 0x45E1" mesages
any clue what i'm do wrong what should be procedure to start it, perhaps sone config files should be updated? :mrgreen:
edit
i even went to lewy20041 ICS firmare because it has ethetnet in gui but also no go.
Dmesg in attachment please help
jm_maclaren
Postby jm_maclaren » Sat Jan 05, 2013 12:19 pm
Not sure why and I can't test here as i don't have that hardware. maybe it automatically loaded Have you tried setting gw and netmask as well as ip address with ifconfig. e.g.
http://www.thegeekstuff.com/2009/03/ifconfig-7-examples-to-configure-network-interface/
b0li
Postby b0li » Sat Jan 05, 2013 12:28 pm
ROOT!!
I did it by method on this link:
http://stuff24.de/blog/howto-root-minix-neo-x5-g4-rk3066/
First step 1 and Superoneclick said: root - but su app didnt get root access.
Second I tried method "update 1" and it worked - with the difference I used "TPSarky-VonDroid-Root new" tool witch came in zip or rar with FW. That tool worked. Not the one in first post of "How to root mk808" thread.
PS: - mk808 has to be turned on when this procedure is working, not turned off like I was doing for past three days
- I think it helped that my stick was connected as MTP device and not mass strorage (setting in upper right corner - three dots - in storage settings)
I hope this helps someone, sorry for my english
bunjimun
Postby bunjimun » Mon Jan 07, 2013 8:42 pm
lewy,
I got my usb to ethenet adapter today, works great straight out the box, brilliant job on the ROM mate.
Here is a link to the adapter for mackowiakp & anyone else who is interested :-
http://www.ebay.co.uk/itm/181036505400? ... 1586.l2649
One thing to note though is it wouldn't work on the OTG port, I had to plug it in the full sized USB port. Just done a speed test on it and I'm getting my full 30 meg download speed from virgin cable.
Wig
did you have to change anything? there are no settings i can find, i have the device plugged in (same one) and......nothing, no ethernet icon, no option to turn it on, either this device is faulty or im missing something
Wig42
Postby Wig42 » Tue Jan 08, 2013 3:36 am
Bunjimun,
No mate I just plugged it in turned off wi-fi and it worked. I had to use the full sized USB port though, it wouldn't work through a hub.
Wig
turbo
Postby turbo » Tue Jan 08, 2013 11:06 am
Great FW, thanks for your work!
bunjimun
Postby bunjimun » Tue Jan 08, 2013 6:14 pm
@wig42 , ah mine must be faulty then, the guy that sold it has been really good and helpfull but the unit is definitly dead, hopefully the replacemet will work, loving this rom so far :)
thanks for the reply
1branchonthevine
Postby 1branchonthevine » Wed Jan 09, 2013 5:22 pm
Can you offer an image for the 8gb version of the MK808? I just updated to this rom, which is looking very sweet by the way, but it seems I lost much of my internal storage space.
Internal storage reports: 1.97GB
Nand Flash reports: 4.38GB
Shouldn't internal storage report just under 8GB?
Also, it looks like Nand is formatted like a flash drive and can even be mounted/unmounted.
Seems like I'm also missing about 2Gb, so what am I missing here?
Also, I followed your install instructions, but I got held up on this line below:
-next go to one-click and boost app anddb
I have no idea if this is an app called "one-click" (which I can't seem to find) or if this is part of the Android Tuner instructions, and if so, where would i find this?
Thanks, and good work by the way!
jav0520
Postby jav0520 » Wed Jan 09, 2013 11:04 pm
I too had this same problem, i couldnt find that app.
Postby lewy20041 » Thu Jan 10, 2013 3:40 pm
1branchonthevine wrote:Can you offer an image for the 8gb version of the MK808? I just updated to this rom, which is looking very sweet by the way, but it seems I lost much of my internal storage space.
its normal that you dont have ful 8gb, try other rom and you wil see thats how it is. as for onclick, its a function of android tuner but only pro version so just skip it.
muratremix
Postby muratremix » Thu Jan 10, 2013 11:11 pm
Is this firmware worth trying? It seems you have to do many things to get root, install apps, change settings etc.
When you install Finless, all came pre-installed and set.
Is there big difference between Finless 1.5 or 1.6 and this one (based on minix x5)?
player911
Postby player911 » Fri Jan 11, 2013 1:07 am
This is probably my favorite rom just because of the hide status bar(F11). Only a few other roms incorporate this feature but none have worked with the F11 key which makes it super easy to hide/show. The rom is also pretty fast and great.
The ONLY problem I have is that it isn't pre-rooted. It really shouldn't be an issue on a custom rom. I've actually figured there would be an update by now but it is what it is. To be honest, I can't even root this rom. It falls on its face, turns everything a purplish tint and never recovers from the second reboot during the root process. This prevents lots of things required.
If this was prerooted and somehow magically had bluetooth support, there would be no question this would be the best.
This one feels a lot more polished then Finless. The boot animation is classy.
I could do without the additional built in apps like Task Manager and Whatever else CPU control is in there. And without root you can't get rid of these. Finless works well too. It is honestly a toss up. I flash between firmwares (testing bluetooth) and this not being rooted really kills it for me. It takes less time to flash another firmware then to try and root it.
flee_glee
Postby flee_glee » Fri Jan 11, 2013 1:51 am
I got the mk808 today and flashed this package, the 1080p one. It is awesome so far. The stock ROM was very poor, black in videos did not have a definition at all. Thanks to every one involved for making this package possible. Does some one know how to bring the status bar back without rebooting. I don,t have an external keyboard to use f11. I'm using droidmote for remote control.
Wig42
Postby Wig42 » Fri Jan 11, 2013 3:33 am
flee_glee
Just put your mouse right at the bottom of the screen and drag upwards.
Wig
b0li
Postby b0li » Fri Jan 11, 2013 10:51 am
@levy20041
Is it possible to incorrporate a gameloft fix from christian troy to this rom?
b0li
Postby b0li » Fri Jan 11, 2013 10:52 am
double post, sorry
Postby lewy20041 » Sat Jan 12, 2013 2:57 am
im not so much into playing games but i will see:)
merlinofchaos
Postby merlinofchaos » Sun Jan 13, 2013 5:15 am
Hello
Thanks for the nice ROM.
I have a problem with CIFS manager when trying to mount a shared folder gives me this error:
"cifs manager java.io.ioexception write failed: EPIPE (broken pipe)"
Sometimes gives me another error:
"Mounting the share has failed with an Error. su: UID 10052 not allowed to su"
With ES File Manager I open this share correctly.
merlinofchaos
Postby merlinofchaos » Sun Jan 13, 2013 2:18 pm
I found a solution to to CIFS Manager. It needs root privilegies to run correctly.
In an attempt to routing encountered the following error: "Solution for ADB error: more than one device and emulator". I added the command "adb devices" in the bat file and found really two devices. One of them was Bluestatsks. After stop it routing was successful.
I found the following bug:
In minimized footer MXPlayer controls hide very quickly and can't be pressed (appear and disappear very quickly)...
Pressing the power button make directly shutdown the device (I don't find a settings for him). Several times I press it accidentally. I think it must be some confirmation first. Best will be asked what do you want: restart or shutdown.
Sory for my bad english...
Thanks again for the beautiful ROM :)
eviltuna
Postby eviltuna » Mon Jan 14, 2013 9:16 am
Great ROM. But its missing the Ethernet settings inside the Settings.apk. Is there anyway to get it back? Its kinda useless for me cause the Wifi on the MK808 is really bad.
Users browsing this forum: Bing [Bot] and 1 guest
