Mk808 download Boot failed
Postby cdn77 » Sun Nov 11, 2012 1:04 pm
Hello,
I had a concern for updating firmware marked with (download failed boot). I have managed to touch the pins 8 and 9, I run RKAndroidTool, I have "Found RKAndroid MaskRom Usb Rock", but whenever I try to make a NAND erase (IDB), he always tells me "Download Boot failed".
Do you have an idea to help me?
cdn77
Re: Mk808 download Boot failed
Postby cdn77 » Tue Nov 13, 2012 4:58 pm
Finally, I manage to make a NAND erase. For cons, I can not make a Flash ROM, I get the error "Download failed IDB"
I have changed USB cable, uninstall and reinstall the drivers finless, installed the usb cable to a hub, but I can not seem to make it work. Would someone an idea?
cdn77
Postby lewy20041 » Tue Nov 13, 2012 6:37 pm
dont use any usb hub when updateing firmware, when updateing use otg port
If i helped you please donate;)
Postby cdn77 » Thu Nov 15, 2012 1:45 am
finally it works, I do not know what I've done more but the result is, I'm happy :lol:
cdn77
Postby spencer531 » Wed Dec 19, 2012 2:10 am
Hi cdn77! I got same situation with you. Could you discribe how to fix it? Very appreciate.
spencer531
Postby dirtytuga » Tue Dec 25, 2012 8:06 pm
I have also this problem (download boot failled)
Any solution for this?
Thank you
dirtytuga
Return to MK808
