use usb wifi adapter on mk808
sna
Wifi won't work
Postby sna » Mon Jan 28, 2013 10:46 pm
I have Airlink101 AWLL5088:
Chipset: Realtek RTL8188CUS
I used the driver by a.alekizoglou but it didn't work. Wifi won't turn on. Switched back to old rkwifi.ko file and now the internal wifi won't turn on either. So now instead of unstable wifi, I have no wifi. Please help! I've attached dmesg and logcat.
a.alekizoglou wrote:1) copy rtl8192cu.ko to /system/lib/modules after you have mounted with rw (I usually run ESexplorer with root options)
2) rename /system/lib/modules/rkwifi.ko -> /system/lib/modules/rkwifi.ko.old in case you need that later
3) rename /system/lib/modules/rtl8192cu.ko -> /system/lib/modules/rkwifi.ko
4) fix permit ions, I do that from terminal, but I think you can do that from ESExplorer as well
chmod go+r /system/lib/modules/rkwifi.ko
chown root:root /system/lib/modules/rkwifi.ko
pestul
Re: use usb wifi adapter on mk808
Postby pestul » Sat Feb 09, 2013 12:19 pm
Will a cisco ae2500 (bcm43236) work with my mk808 on finless 1.6? Tried the powered usb hub method but it just connects to the internal wifi.
pestul
Postby pestul » Sat Feb 09, 2013 2:33 pm
Tried the precompiled bcmdhd.ko from page 4 but it looks like I'll have to make my own for bcm43236.
ilearner3
Postby ilearner3 » Tue Feb 19, 2013 4:33 am
rainlake wrote:
bthoven wrote:Hi rainlake
I uploaded a firmware yesterday. which have already modified. you can try.
http://ppl.ug/iK4AVhUMmGI/
Hi, rainlake
Does this firmware support a RTL8192CU/RTL8181 USB2.0 Wifi dongle PNP on MK808(not MK808b)? I don't know too much about Linux and don't have Linux OS, to buy a USB 2.0 wifi dongle seems much easier in this case. The firmware you provided, named with buletooth.........., but MK808 doesn't have BT on it.
Kindly advise on how to flash this firmware, with which flashtool? do I need to flash the kernel.img/boot.img or just flash the system.img? Does this firmware also support 1080p OS?
skysurf
how do I do it by working for my USB Wifi TP-Link TL-WN422G
Postby skysurf » Sat Feb 23, 2013 2:38 pm
how do I do it by working for my USB Wifi TP-Link TL-WN422G v2 (Chipset: Atheros AR927) on mk808b?
I don't know much about this, can anyone help me please?
already tried what is described on the site:
http://www.freaktab.com/showthread.php? ... #post53580
I'm waiting for the answer ...
help me please ...
thanks .. ;)
rainlake wrote:thanks for Omegamoon post link of mk808 kernel. And sorry for my bad english.
I have a dlink dwa-135 wifi adapter, chipset is rtl8192cu. downloaded driver from realtek website.
modify Makefile of driver.
(1) add -fno-pic :EXTRA_CFLAGS += -Wno-uninitialized -fno-pic
(2) add rock3066
CONFIG_PLATFORM_I386_PC = n
CONFIG_PLATFORM_ARM_RK3066 = y
ifeq ($(CONFIG_PLATFORM_ARM_RK3066), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ANDROID -DCONFIG_PLATFORM_ROCKCHIPS -DCONFIG_MINIMAL_MEMORY_USAGE
ARCH := arm
CROSS_COMPILE := [***1***]
KSRC := [****2****]
MODULE_NAME := rtl8192cu
endif
[***1***] is location of arm toolchain. I use ndk. like android-ndk-r8/toolchains/arm-linux-androideabi-4.4.3/prebuilt/linux-x86/bin/arm-linux-androideabi-
[****2****] is locktion of rk3066 kernel.
and execute make in driver directory. you will get drive module rtl8192cu.ko.
enable /system write: adb remount . or mount -o rw,remount /system in terminal emulator.
push it to mk808: adb push rtl8192cu.ko /system/lib/modules.
and insmod: insmod /system/lib/modules/rtl8192cu.ko.
disable wifi in android settings->wifi
plugin wifi adapter then reenable wifi in android wifi settings.
now my wifi adapter is bring up and connected to my router.
tested streaming youtube and 1080p films on my nas. all of them works fine.
I believe other wifi adapters will work fine if you can build driver for mk808.
to auto bring up wifi adapter. I replaced /system/lib/modules/rkwifi.ko with rtl8192cu.ko. everything works fine. wifi adapter will bring up automaticly.
pricer
Postby pricer » Fri Mar 01, 2013 6:30 am
Ebay "300Mbps" USB Wifi
In fact Realtek 8188 150Mbps
leolas
Postby leolas » Fri Mar 01, 2013 10:04 am
pricer wrote:Ebay "300Mbps" USB Wifi
Ebay Link? and driver link to add pls?
BoJaXz
Postby BoJaXz » Mon Mar 04, 2013 8:41 am
I already have an unused usb wifi n (200Mbps) with internal chipset RTL8191SU (it is compatible with most Realtek media player).
Could you please let me know what information you need from me in order to help me use this dongle.
Thanks in advance.
try this one.
if it does not work. post your dmesg and logcat.
Awesome! This worked with my airlink 101 300mbps usb wifi adapter, thanks!!! :mrgreen:
endera
Postby endera » Thu Mar 07, 2013 1:20 am
I have AirLive WT-2000 usb wifi adapter RT73 chipset . How its configure?
http://www.airlive.com/products/WT-2000 ... 0usb.shtml
linux driver
http://fs.airlive.com/airlive_fileserve ... boGUSB.zip
fratello
Re: use usb wifi adapter on mk808 - Driver for TPLINK 723N
Postby fratello » Fri Mar 08, 2013 2:19 pm
a.alekizoglou wrote:Thanks to rainlake and ratri, after a lot of digging into Realtek's RTL8192CU and RTL8188CUS driver (http://www.realtek.com.tw/DOWNLOADS/dow ... Down=false) I managed to build the driver that's working for RTL8188CUS based devices.
This is what I've bought http://www.tp-link.com/en/products/deta ... =TL-WN723N
The device's ID is 0BDA:8176 REV_0200
4) fix permitions, I do that from terminal, but I think you can do that from ESExplorer as well
...I made the first three steps ;when I get to the fourth step, I use "Android terminal emulator" (from Market...) , but, after typing "chmod go+r /system/lib/modules/rkwifi.ko", I have the message "bad mod" !
What I do wrong ? Maybe I must BEFORE typing this command to type "su" ?! Forgive my ignorance... Thanks in advance for support !
LE : Even if I type (at start) "su" command, "chmod...." return "bad mode" (this time I used teminal from RomToolBox) :( ...
I'm using Finless 1.5a.
LLE : My TP-LINK is vers.1.1 ! I think it's have RTL8188SU (http://wikidevi.com/wiki/TP-LINK_TL-WN723N_v1) so it's use another Linux driver - r8712u ...
Can somebody helping me with a proper .ko file ? I will be verry gratefull !
napalmique
Postby napalmique » Sat Mar 09, 2013 5:26 pm
The problem with rtl8192cu.ko driver was that in autoconf.g the line for CONFIG_IOCTL_CFG80211 is remarked. Therefore ioctl is not build with the driver. So I removed the remark and rebuild the driver. It is now working for my device according to the instructions rainlake has provided. That is:
chmod go+r /system/lib/modules/rtl8192cu.ko
chown root:root /system/lib/modules/rtl8192cu.ko
So I include the driver in case someone else with RTL8188CUS chipset wants to check.
I have this dongle:
http://service.targa.de/antworten.php?l ... 11&serial=
WIth 8188cu chipset and the exactly the same usb id like your, I downloaded your driver, I turn wifi off, I load the driver, I connect the dongle, I turn wifi on, and it freezes, I have a MK808 with finless 1.6, so kernel 3.0.8.
Any ideas ?
Thanks in advance.
hcallahan
Postby hcallahan » Sat Mar 09, 2013 8:54 pm
Hi Armtvtech community and developers,
I've been enjoying my mk808 for some months now and the wifi antennas decided to crap out on me. The signal drops out constantly, causing me to switch it on and off. Very annoying problem. Coincidentally earlier this week my brother came home with a linksys usb wifi adapter :). It's the model Linksys wubs54g (v4) which has the Ralink rt2500usb chipset.
I've downloaded the driver pack posted on p.4 of this thread, which contained the driver (rt2500usb.ko) but it doesn't work. I get the 'Exec format error' when trying to insmod in terminal emulator (followed some instructions from this thread, have no experience with this stuff). I've read that it's not working because it's compiled for a different kernel. I'm on Finless 1.6 right now (kernel 3.0.8+). I'd really appreciate it if anyone with some time on his hands could compile it for this kernel. Here's a link to the driver pack which contains rt2500usb.sys. (is this the right one?) http://downloads.linksys.com/downloads/ ... -eu_dr.zip
brueggi
Postby brueggi » Wed Mar 13, 2013 1:53 am
shooter54 wrote:So, i try it again and again. But no luck with my D-Link DWA 125 (Ralink RT3070) chip set.
He find my Roter that shows up with 300 MBit.
He try to connect but it ends with a time out. I think it is the config file (the RT2870STA.dat file)
Did you make any progress on this? I'm encountering the same issue with my DWA-140. The MK808 tries to connect to my router but according to the router's log a wrong (or no?) wifi key is used. The settings in RT2870STA regarding SSID, Encryption and PSK are OK. I'll post the whole file later on when I have access to the device again.
vargalex
Postby vargalex » Wed Mar 13, 2013 7:09 pm
Hi!
I have an MK808B (original, with RK903 WiFi/Bluetooth module on board). I would like to use my TP-Link TL-WN821N V3 USB Wifi instead of built in RK903.
I successfully built the kernel modules for this device (ath.ko, ath9k_hw.ko, ath9k_common.ko, ath9k_htc.ko).
I can load the modules with insmod, than in dmesg output I see, that the device is correct detected, and the necessary firmware successfully uploaded. But when I turn the Wifi on in the menu, than the MK808B freezes.
My first problem is: I cannot unload the rkwifi.ko with rmmod, because there is no rkwifi in lsmod output!
I have rename the rkwifi.ko to rkwifi.ko_old and rebooted the device. Than I have no Wifi (even if I loaded the ath modules), and in dmesg (when I try to turn on the wifi) output I see the following message: "Current wifi chip is RK903.".
I also tried to edit my init.rk30board.rc (flashed as new boot.img) with:
service wpa_supplicant /system/bin/wpa_supplicant \
-Dwext -iwlan0 -c/data/misc/wifi/wpa_supplicant.conf
and in boot section:
rmmod /system/lib/modules/rkwifi.ko
insmod /system/lib/modules/ath.ko
insmod /system/lib/modules/ath9k_hw.ko
insmod /system/lib/modules/ath9k_common.ko
insmod /system/lib/modules/ath9k_htc.ko
but the result is the same (after boot use the device the RK903, and on wifi turn off, than on the device freezes).
Have you any idea what my problem is? Where is defined, that the device has an RK903 Wifi module (I mean on "Current wifi chip is RK903." message)? Can I modify this definition?
This is the situation with original factory firmware and with Finless 1.7.
Thanks for your help,
vargalex
hengky.tandra
Postby hengky.tandra » Wed Mar 20, 2013 9:21 pm
rtl8192cu for Android 4.2.2 (3.0.36+) ??? :?
pshell
Postby pshell » Wed Mar 27, 2013 5:43 pm
Anyone compiled the rtl8192cu driver for 3.0.36+ ?
rishidoshi
Postby rishidoshi » Mon Apr 01, 2013 2:47 am
I have a dlink dwa123. chipset it says is RT3370.
Which drivers will work with it?
please help . thanks :)
ninggu2008
Postby ninggu2008 » Thu Apr 04, 2013 9:29 am
Works very well with my mk808+RTL8188CU, no bugs about wifi now.
freeman3020
Postby freeman3020 » Thu Apr 04, 2013 12:23 pm
hi all
it's now 1 week tring to use usb wifi in 2dark4u kernel , because i havn't source for kernel , i used precompiled drivers
i have rt73 usb wifi trying all ko without result, as i renamed it to rtwifi.ko , but kernel 3.0.8+ use wlan.ko can i use precompiled drivers?????
i found in /system/lib/module/ file with name 8192cu.ko is this mean i can use it with TP-LINK TL-WN723N and save efforts
plz help
hitman72
Postby hitman72 » Fri Apr 05, 2013 4:04 am
ciao, I have a Wifi TP-Link TL-WN422G v2 (Chipset: Atheros AR9271) too. as for the other users, giving the following commands: insmod ath.ko, insmod ath9k.ko and insmod ath9k_common.ko I have no error messages in terminal but usb wifi dongle does not active... I have also dongles with RTL8192SU but I have not found anything about an 8192su.ko online... I think the only alternative is to find a wifi dongle with rtl8192cu. ciao :-)
edit: found this on xda for asus TF300T and Atheros AR9271. but now I am at work and I can't try
http://forum.xda-developers.com/showthr ... ?t=2133854
edit 2: doesn't work... "(Exec format error)"... different cpu... pity
